Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3020 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4609 Views
  • 1 replies
  • 16 Helpful votes
Hello,We're having severe issues with our SRW248G4's1. Web interface is extremely flaky, often failing to completely load and requiring a refresh to finish2. Web interface is IE5.5 to 7 not IE8 or a useful browser (Firefox), It did work in IE8 with f...
dave-lew99 by Level 1
  • 12909 Views
  • 14 replies
Hey everyone,I need some help setting up IP based ACLs for voip phones on my Cisco switch (SGE2010p).Basically I have no idea what to put in the window (see attached image)What protocols?  What IP addresses? what ports?  do I need to put the DSCP num...
timjeens1 by Level 1
  • 1531 Views
  • 7 replies
Let me start off by stating that I am a novice at setting up Cisco routers, I have a few years of networking form the server side of things just beginning to work on the switch side.I am trying to configure a sg200-8 to have three VLANs.Here are the ...
khg112578 by Level 1
  • 2390 Views
  • 7 replies
I've just installed a cisco small  business SG 200-26P switch, which I did to get POE function. Replacing  a Dlink switch which was working perfectly. Now that I've done that, LTSP terminals that I am using  on this small network have started locking...
tjston by Level 1
  • 1062 Views
  • 3 replies
ネットワーク初級者です。WS-C2960Sでスタックを組んでいるのですが、switchコマンドなどで設定した「メンバ番号」や「プライオリティ」などの設定情報はどこに保存されるのでしょうか?startup-configなどには(表面上)保存されていないかと思いますが、いったいどこにあるのか・・・悩み中です
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
