My catalyst cisco switch 3650 48 4x1g could not get ip from our linux based DHCP server
We have our DHCP server on the network, that dhcp server is working on linux and configuring all other switches and  PC desktop as usual,
we have 2960 plus switches mostly, but recently we purchased 3650 switch and we trying to configure it. Usually when the PC or Switch is booting on the network is geting IP and Hostname automaticaly from our DHCP server.
this one 3650 is not geting ip neigher hostname. and i don't know where is the problem.
can you help?
usualy when we have this kind of a problem we delete *.text from the memory, i am attaching you the photo. i don't see any "text" files  in there. so i cannot understand the problem.
please help.
17 Replies 17
You would say no if you don't want use to auto install and want to configure it yourself
If you have access like that to the switch just set the hostname and ip address manually that you set on the dhcp server and then push the config file
i already done that
./load_cisco_conf    Hostname   worked
but
rsh   Hostname   write memory   did not worked
(conf t)hostname xxxxx
(conf t)exit
# copy run start
