Need info about the IOS for 4503
Peter_mlr
Hi There,
we are running a cisco 4503 with bootflash:cat4000-i5s-mz.122-20.EW4.bin  IOS on that, we are informed to upgrade the IOS on that. However, no info on which IOS has to be deployed on that. Hence, can some one please suggest the latest and upgraded IOS for the Cisco 4503 switch.
The memory details are below
Switch#  Show verion
IOS (tm) Catalyst 4000 L3 Switch Software (cat4000-I5S-M), Version 12.2(20)EW4, RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2006 by cisco Systems, Inc.
Compiled Fri 13-Oct-06 11:35 by tinhuang
Image text-base: 0x00000000, data-base: 0x011F879C
ROM: 12.2(31r)SG2
Dagobah Revision 226, Swamp Revision 34
PT_HE_Main_110.254 uptime is 4 weeks, 1 day, 18 hours, 33 minutes
System returned to ROM by reload
System restarted at 17:10:55 IST Mon Feb 24 2014
System image file is "bootflash:cat4000-i5s-mz.122-20.EW4.bin"
cisco WS-C4503 (MPC8245) processor (revision 4) with 524288K bytes of memory.
Processor board ID FOX103809BG
MPC8245 CPU at 400Mhz, Supervisor V
Last reset from Reload
156 Virtual Ethernet/IEEE 802.3  interface(s)
98 Gigabit Ethernet/IEEE 802.3 interface(s)
511K bytes of non-volatile configuration memory.
Configuration register is 0x2101
Switch # dir
Directory of bootflash:/
    1  -rwx    11343796   Dec 5 2006 11:28:14 +05:30  cat4000-i5s-mz.122-20.EW4.bin
59244544 bytes total (47900620 bytes free)
Switch #
Thank you
Peter
Leo Laohoo
Latest and greates IOS selection menu can be found here.
Make sure you take the time to read the Release Notes.
Leo Laohoo
Thank you for taking the time to rate our posts, Peter.  :)
