Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We recently announced the release of our self-serve virtual assistant. You can read the full announcement here. Videos and documents are available within a click for our latest products. Once you've told the bot what device you're using, the context ...
CoreyP319 by Cisco Employee
  • 3013 Views
  • 1 replies
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 4603 Views
  • 1 replies
  • 16 Helpful votes
Hi all,I have recently received a SG200-26P poe switch to potentially upgrade the office switch.So on first boot - it went through its post, got a solid green light.I then connected my PC to the first port to try and configure it via the web interfac...
Probably more pressing information than what is below, but if I have a SG300 in layer 3 mode, can it handle multiple DHCP scopes using one nic out of the server, or do I need to add a router.            I have two SG300's that I'm working with and I ...
I am trying to get multicast across VLANs working on my SG500 and since it doesn't have PIM, I think the Multicast-TV option can work.However, now my clients are getting switched to the Multicast-TV VLAN instead of the regular VLAN they are assigned....
DJX995 by Level 3
  • 1872 Views
  • 6 replies
  Investigating a slow transmission issue at a site with 3 switches.   A 200 Series Switch and a C2960G hang off the SG300-10 which is currently running in layer 3 mode with qos enabled but not routing.   Currently no VoIP and all classification and ...
Tomorrow I will be setting up a simple router and switch configuration in a small office.  The network will be a flat network with no seperate vlan for voice and data.  We will have Cisco 7961 Cisco phones connecting back to our main office via a sit...
andym5041 by Level 1
  • 2484 Views
  • 5 replies
On a port or vlan that doesn't need acl filtering is it more effecient to have nothing or a single permit ip any any?  I understand that there's a default implied deny ip any any to block anything not allowed in a proceeding permit statement  but I a...
viningele by Level 3
  • 632 Views
  • 1 replies
Hi all,i've installed switch SF300 48 ports for IP phone environtment, i configured it as guide, if i attach ip phone it works normally,but when i plug laptop to switch port, it cannot connect to anywhere, then i tried to change native vlan for smart...
ahmed by Level 1
  • 1988 Views
  • 7 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
