12-20-2021 09:15 PM
Project manager ordered a new SX550X-16FT switch to connect seven IP cams to a BOSCH NVR/server. It doesn’t appear to be a POE switch and I see no POE settings on the web interface. The switch comparison on Cisco website says it has POE. Does anyone know for sure if it is capable of POE? Does it need to be turned on in programming? Thanks.
Solved! Go to Solution.
12-20-2021 11:41 PM
this switch is not PoE capable.
12-20-2021 10:54 PM - edited 12-20-2021 10:55 PM
Cisco 550X Series Stackable Managed Switches Data Sheet
SX550X-16FT has the following description:
● 8 x 10 Gigabit Ethernet 10GBase-T copper port
● 8 x 10 Gigabit Ethernet SFP+ (dedicated)
● 1 x Gigabit Ethernet management port
12-20-2021 11:41 PM
