No command line interface on SF200 small business smart switches?
Ricky S
Level 3
Level 3
Hi all, we just received 5 new SF200-48 Smart Switches for small business. I noticed only way I can configure them is by using the web gui. Is there a way to enable good old CLI?
2 Accepted Solutions
Tom Watts
Hi Ricky, no this unit does not have a CLI support.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Correct, each port is a collision domain. It is a 'normal switch'.
-Tom
6 Replies 6
Tom Watts
-Tom
Thanks Thomas. I guess I made a mistake ordering these then. I'm a CLI guy.
Please look in to the SG500 series and the SG300 series. Both units have a full supported CLI.
-Tom
Thanks. Will do.
I do have another quick question, possibly a dumb one. The reason why I ordered 5 of these smart switches is to replace a bunch of hubs that are still in operation at one of our offices. Now is it safe to assume that these "smart switches" will infact work like traditional switches i.e. separate collision domain on each port? I guess what I am trying to ask is whether or not "smart switch" is just another name for a hub in Cisco's language? I don't want to roll these out and then end up with the same situation that I currently have with the hubs.
-Tom
Great. Thanks again.
