10-12-2011 11:51 AM
I recently purchased an SG300-28P. I have 2 VLANS/subnets that are successfully routing between them.
Machines on both sides can ping each other just fine, but none of the usual Windows/NetBIOS browsing is possible. I've recently learned that NetBIOS is not usually forwarded between subnets. How would I enable NetBIOS packet forwarding between my subnets?
Reading the manual, it seems like enabling UDP Relay might be the answer but I've been unable to get it to work (same with DHCP relay). Any help would be greatly appreciated.
Gerry
10-12-2011 12:17 PM
Gerry,
The reason we create multiple vlan/subnet segments is to cut down on this type of traffic. Each vlan segment is it's on broadcast domain. The SG300 doesn't support Multicast/broadcast routing. So you won't be able to route broadcast or multicast traffic over vlans.
Jasbryan
10-12-2011 08:45 PM
Hi Gerry
I would like to expand a bit on the previous answer.
The 300 series switch, when in layer 3 mode does support UDP port forwarding for such protocols as netbios.
Rememeber each GUI page has specific help text to understand the command, just select Help at the top right of the screen .
Check out the option below, which is only visible when you put the switch into layer 3 mode, it is like a router ip helper command, and used to port forward and UDP broadcasts to a unicast address.
port prot. description
137 | UDP | netbios-ns | nbname | NETBIOS Name Service |
138 | UDP | netbios-dgm | nbdatagram | NETBIOS Datagram Service |
This screen capture looks a bit weird, as I do not have multiple VLANs on the switch, only a single VLAN, so it pulled up the IP address of VLAN 1 of my SG300-10P (SRW2008P-K9-NA) switch.
This GUI option could take a Netbios broadcast from within VLANx. (where x normally = 2 to 4094) and unicast it to the windows server.
You have to add two entries to port forward NETBIOS, UDP ports 137 and 138.
Switch then unicast, these VLAN x broadcasts to a server of interest at a destination IP address. Or this option allows for floods it to all addresses if you state 255.255.255.255. But personally I like setting a specific Windows server IP destination address of interest.
Please, make absolutely sure WAN router should have a route pointing back to the VLAN x network and even feel free to add a persistant route withijn the server if you wish, that also points to VLANx network.. never hurts
Note: the wan router should be able to ping VLAN x IP address of the switch, otherwise IP hosts will not be able to communicate back with IP hosts in VLAN x..
DHCP relay is also similar, but your router has to be able to recognise/differentiate DHCP requests with option 82 or VLAN ID, and allocate a different scope of addresses to the new VLAN.
Good luck and give that a try.
regards Dave
10-17-2011 03:32 PM
Dave,
Thanks very much for the response.
* I added UDP entries for 137,138, using source as ALL and destination as the IP addresses for my PDC, BDC and WINS IP addresses on VLAN2
* I also disabled the firewall on my XP client in VLAN3 since it might block traffic from those ports from different subnets
It didn't work. When I say "didn't work" I mean I can't use NET USE or NET VIEW on my VLAN3 to see shares on VLAN2. Ping works just fine in both directions.
Strangely, I got on the BDC on VLAN2 and successfully mapped a SMB share on VLAN3 (the opposite direction of how I want to go). With a couple minutes of that mapping, the machine with the SMB share on VLAN3 was then able to map drives on VLAN2 (the direction I want to go). I'm not sure why that's happening.
Is there a log indicating which packets are being dropped, preventing NetBIOS from working? I couldn't find a way to track dropped packets.
Perhaps I'm overlooking something obvious.
Any insight would be greatly appreciated. Thanks,
GV
10-18-2011 07:47 AM
Hi Gerry,
What about the source address being the IP address associated with VLAN3 ?
regards Dave
09-13-2012 06:17 AM
Hi Gerry,
Hi David,
Did you ever resolve this issue? I have a similar issue with WOL packets. I want to broadcast a magic WOL packet from one VLAN 200 (10.1.1.0) to VLAN300 (10.2.2.0). For this I've configured an UDP-Relay (GUI menu IP Configuration) for UDP-Port 7 to 255.255.255.255 (this should flood all interfaces with the paket) with the source IP configured as 10.1.1.0. However despite the configuration, the WOL packet doesn't arrive at the destination. When I send the packet in the same VLAN (10.2.2.0) it works fine. Did I miss something?
I've opened a new thread for this:
https://supportforums.cisco.com/thread/2170291
Many thanks for your help!
Kind regards,
Romeo
09-20-2012 09:15 AM
Hello Romeo,
No, unfortunately I never resolved this issue. I eventually decided to flatten my LAN so there were no VLANs.
Hope you find an answer,
GV
09-21-2012 06:03 PM
Hi guys, I delete the other posts because I have labbed this scenario and successfully made it work.
Here are the lab considerations:
1 - SG300-28 switch in layer 3 mode
2 - Window Vista Home and a Window XP pro computer
3 - There was no router or DHCP service, I statically assigned the computers so it is basically a simply point to point
From the CLI here is the configuration;
config t
vlan database
vlan 2
int vlan 2
ip address 192.168.2.254 /24
int vlan 1
ip address 192.168.1.254 /24
int gi24
switchport mode access
switchport access vlan 2
int gi12
ip helper-address all 255.255.255.255 137 138
do wr mem
From this configuration, the ip helper-address toggles the UDP relay. The ALL represents BOTH of the SVI. The 255.255.255.255 broadcasting to all IP on the switch. The 137 and 138 are obviously the NetBIOS ports.
The Computer \\Tom is 192.168.2.10 /24 at 192.168.2.254 gateway connecting to port 24. The computer \\Cisco is connecting to port 12 at 19.168.1.10 /24 at 192.168.1.254 gateway.
Initially, this did not work when I used Start Menu -> Run \\Tom
I then disabled the Windows Firewall for \\Tom
Immediately I had zero issues to access the computer.
In addition, I have verified 2 other methods for the syntax.
ip address-helper all 192.168.1.10 137 138
This will allow only to the specific host from all SVI
ip helper-address all 192.168.1.255 137 138
This will allow to flood all of the 192.168.1.0 subnet
Here is a documentation I just created with the GUI
https://supportforums.cisco.com/docs/DOC-27022
-Tom
Please rate helpful posts
09-22-2012 02:49 AM
Dear Tom,
Great, thank you so much for taking time to document this! I think in my case the issue is solved, I can ping and access all hosts in the other VLAN using their Netbios name.
Regarding the Network Browsing, I am using Windows 7, and by default the firewall only allows the Network Discovery within the local subnet. I had to add the other VLAN's subnet to the scope:
This you'll find under Control Panel\System and Security\Windows Firewall and then "Advanced Settings" on the left side.
Once again, thanks for your committed support.
Kind regards,
Romeo
