07-25-2013 08:27 AM
I've bought two SG 200-08P which have their 1-4 ports who can delivered PoE.
Whatever the PoE equipments I plug into those ports, it doesn't work.
If I plug a non PoE equipment in the 1-8 ports it's working fine.
I can log into the web interface of the switch, and when I go to "Port Management > PoE > Properties", I can see the following screen:
I don't know how switch the "Power" option to "On"...
I have the exactly same issue with a second and new SG 200-08P.
I've changed the firmware and I am now in the 1.0.6.2 version but I have the problem with the original version.
I also try to reset the switch several times, but it doesn't change anything.
Is anyone has a idea to what can I do or test ?
Thanks.
07-25-2013 10:39 AM
Hi Xavier, at a factory default parameter the POE is enabled. What is the vendor and model of the device you're trying to connect?
-Tom
Please mark answered for helpful posts
07-25-2013 11:55 PM
Hi Tom,
For now, I only try to connect differents Siemens IP phones (1 or 2 or 3 PoE classes) : OpenStage 20,
OpenStage 40 and OpenStage 60.
Those Siemens phones are working fine with other PoE switches like linksys, HP, catalyst, 300 series, Netgear ...
I've just noticed something interesting, in the "Status and Statistics > View Log > RAM Memory" menu :
When I clear the logs, only my computer is connected on port 8...
I'll try to find other PoE devices, to test with.
Regards.
07-26-2013 06:37 AM
Hi Xavier, if the POE is not working for any connection then it's a bad switch. If it works for some but not other it's a diffrent problem.
-Tom
