Port Based Security Issue (802.1x Wired Network) Printers are FAILED
sundesa1977
I am getting an error in Cisco 2960 and HP ProCurve 2920 Switches I am having an issue with Printers only to directly go to VLAN1 as I can't setup for authentication, below is the port configuration.
Everything is working fine as of my need except Printers :/
switchport mode access
switchport voice vlan 15
authentication event fail action next-method
authentication event no-response action authorize vlan 10
authentication host-mode multi-host
authentication priority mab dot1x
authentication port-control auto
mab
dot1x pae authenticator
spanning-tree portfast
Thanks in well advance to support.
Faisal Raza
cofee
Level 5
Level 5
please share port security configuaration on switch ports.
This was deployed well. The supplicant is getting the Guest VLAN and the other relevant are getting their concern VLANs. Now I need Windows Group Policy settings to deploy to clients.
If anyone can provide step by step procedure to deploy user based / group based setup for GPO :)
Thanks.
Here's the configuration of interfaces :)
mab
Here everything is working absolutely fine but I've an issue of Printers. I need printers to go in VLAN1 automatically.
Could you please share if there's any solution for this :)
