Problem between 2 VLAN
adbemmaus
I use CISCO ESW 520 since 2year and i have a strange problem with new VLAN.
I add a new VLAN for a new activity (VLAN 9), in this VLAN i have a DCPH and a system that can erase operating system on boot on network.
But this VLAN 9 communicate with the VLAN 4.
It's the first time that I see that, because they are no problem with the other VLAN, and the only RJ45 with the VLAN 9 untagged are not plug.
Have you ever seen that?
I continue the investigation but if you have idea.
Tom Watts
Hi Thibaud, let me try to clarify.
You created a VLAN 9. There is only 1 port  a member of VLAN 9 which connecting to a DHCP/server. Does this VLAN 9 exist anywhere else?
The ports connecting to your router / other switches, are these tagging VLAN 9? This would be expected to happen automatically because of the smart port macros.
-Tom
Please rate helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Ok I just change Trunk Vlan port to Access Port VLAN and the problem is solved.
Thanks for your help.
