09-12-2011 10:43 AM
Hi !
I haved configured on SF-302P an qinq tunnel port!
With
interface FastE1
switchport mode customer
switchport customer vlan X
Vlan transparency work through the tunnel and all ethernet frames passes in correct way the tunnel !
Is it possible to tunnel for example also the cdp protocoll because on the SF-302P it doesnt work ?
On a normal cisco switch I use this config:
interface FastEthernet0/21
switchport access vlan X
switchport mode dot1q-tunnel
l2protocol-tunnel cdp
l2protocol-tunnel stp
l2protocol-tunnel vtp
no cdp enable
kind regards
Christoph
08-16-2012 07:37 PM
Hi Christopher, I know this is an older post now, but did you ever find an answer to this question?
I am in the exact same position at the moment and cannot find an answer.
Brian
08-21-2012 11:35 PM
Hi Brian !
Sorry no answer 😞
kind regards
Christoph
02-13-2023 08:52 AM
This is exactly my problem.. any found a workaround?
02-13-2023 10:23 AM
what is the problem post more information here with firmware using what is not working
refer admin guide :
02-13-2023 02:07 PM
Thank you Balaji. I already red the guide but I could not find anything l2protocols related. This is the topoligy... the problem is that STP/CDP/LACP dont work between the ends.
