10-25-2022 11:55 PM
Is it possible to have mixed port speed down to 1Gbps?
We need to replace uplink to 10Gbps from 2x1Gbps port group. And due to old fibre cables it trouble upgrade all 8 linked switches to 10Gbps at the same time.
Switch to be replaced is SG350-10SFP
Solved! Go to Solution.
10-26-2022 01:51 AM
Yes. Please note the CBS350-12XS 10G SFP+ ports do support 1G SFP modules as well (refer to the supported "SFP modules" section at https://www.cisco.com/c/en/us/products/collateral/switches/business-350-series-managed-switches/datasheet-c78-744156.html).
10-26-2022 01:51 AM
