05-13-2011 01:04 AM
Hello there,
We are trying to config vlan 10 for data and vlan 20 for voice on the same port - port 1 of swtich SF300-24P to run both data and voice on different vlans.
How can we achieve this?
Do I have to add vlan 10 as an untagged vlan to port 1 and add vlan 20 as an tagged vlan to port 1?
If I do not want to assign the native vlan 1 to port 1, how can I remove it ? The GUI page - assign VLAN to port does not allow to remove it.
Aslo, what mode shall I set up on port 1? General, trunk or access ?
Appreciate your reply and helps.
Tony
05-31-2011 10:50 AM
Actually the end of sale date on the 7961 phones was January 19 2010.
More specifically what I was referrring to was being able to use 802dot1Q encapsulation so these switches could work together with 2800 and 2900 switches for multiple vlans per interface. For that matter they wont even work with an ASA5505 in a trunked environment.
05-31-2011 11:02 AM
7960 and 7940 which is what was discussed in this post was EOL'd back in 2002:
802.1Q encapsulation works with all standards-based products, including the ones you've mentioned. Make sure that you set the encapsulation to "dot1q" on the router side:
Contact the Support org and they will help you through getting this to work.
BTW, the reason why you're not seeing the phone as an LLDP Neighbor is because those older phones do not support LLDP-MED. You have to set the voice VLAN on the phone manually.
12-22-2011 07:44 AM
This is an old thread, but for the benefit of anyone searching, a firmware release has been made that allows the 200 and 300 series Small Business switches to support Cisco Inline Power, aka pre-standard POE.
https://supportforums.cisco.com/docs/DOC-18337
This means that those switches will indeed power the CP-7940/CP-7960 and the CP-7940G/CP7960G, even though they do not support the 802.3af standard. A number of older third-party switches also support CIP, but there is no list that I have found that specifies which ones do and do not. The CP-7941/CP-7961 that tahequivoice referred to are different phones (though they look nearly identical) that do support 802.3af out of the box.
Please note, however, that the updated firmware has not been released for all 200 and 300 series switches. As the comments at that link mention, the firmware has yet to be released for the SG200-08P, among others.
As for throwing these phones out because they are "kinda old"? That makes no sense and would be extremely wasteful. The Panoptic adapters mentioned seem to be available for $27.00 each, which really might be the best long-term solution, as it makes them 802.3af compliant (though I have never used one).
12-23-2011 01:23 PM
All 300 series switches and all 200 series switches support Cisco Inline power except for SG200-08P and the 200E models.These models use a different chipset and software and do not support this capability.
Ivor
05-15-2015 06:11 AM
The issue I think has nothing to do with the model of phone am using cp3905 and still cannot get what I want. It will pick the untagged vlan ip and give the system same. What I want is that the phone pick its voice vlan and give the pc connected to it data vlan. I have tried all the suggestions and still cannot get it working as I want. Not that the phone does not work with the data vlan but I want it to take its own vlan.
05-15-2015 09:19 AM
Im sorry you haven't been able to resolve this issue in so long.
Mid you are already using the port as trunk with VLAN 10 untagged and 20 tagged then the issue is not on the port but somewhere else on the configuration.
The first step is probably gathering all the network topology showing the voice devices, phones, pbx and such. It will be important to show the ports evetythibG is conneCted to showing the Vlans and port configuration.
I hope this helps.
06-15-2015 03:38 AM
here is my layer 2 switch configuration.
I can connect the phone now and it will get voice vlan but the PC connected to the phone or the port cannot get data vlan.
Is there anything that I did wrong or did not do
sh run
config-file-header
RACKCSW3
v1.3.0.62 / R750_NIK_1_3_647_260
CLI v1.0
set system mode switch
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
default-vlan vlan 500
exit
vlan database
vlan 1,11,14,110,113
exit
voice vlan id 113
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
port-channel load-balance src-dst-mac-ip
gvrp enable
no lldp med network-policy voice auto
lldp med network-policy 1 voice vlan 113 vlan-type tagged
qos trust cos-dscp
qos dscp-mutation
wrr-queue cos-map 2 0
wrr-queue cos-map 3 2
wrr-queue cos-map 3 6
wrr-queue cos-map 3 7
qos wrr-queue wrtd
ip access-list extended VVlan-Voice
exit
priority-queue out num-of-queues 0
hostname RACKCSW3
no logging console
aaa authentication enable telnet enable
enable password level 15 encrypted 6ac17a623746f239d2a26bb455570baa07ded8e4
no passwords complexity enable
ip ssh server
snmp-server location "RACK C"
snmp-server community default
no ip http server
clock timezone " " 1
no ip domain lookup
interface vlan 1
no ip address dhcp
interface vlan 11
name data
interface vlan 113
name voice
interface vlan 500
name management
ip address 172.23.0.11 255.255.255.0
interface fastethernet1
switchport trunk allowed vlan add 113
switchport trunk native vlan 11
no lldp transmit
lldp med disable
macro description "switch | ip_phone_desktop"
switchport default-vlan tagged
interface fastethernet2
storm-control broadcast enable
storm-control broadcast level 10
storm-control include-multicast
port security max 10
port security mode max-addresses
port security discard trap 60
spanning-tree portfast
no lldp transmit
lldp optional-tlv sys-cap
lldp med enable network-policy location
lldp med network-policy add 1
interface fastethernet3
no lldp transmit
lldp med disable
interface gigabitethernet3
description UPLINK-FROM-CORESWITCH
spanning-tree link-type point-to-point
channel-group 2 mode auto
macro description switch
interface gigabitethernet4
interface Port-channel2
description "uplink redundancy coreswitch"
switchport trunk allowed vlan add 1,14,110,113
!next command is internal.
macro auto smartport dynamic_type switch
exit
macro auto processing type host enabled
macro auto processing type router enabled
macro auto built-in parameters desktop $max_hosts 10 $native_vlan 11
macro auto built-in parameters server $max_hosts 10 $native_vlan 11
macro auto built-in parameters host $max_hosts 10 $native_vlan 11
macro auto built-in parameters ip_phone $max_hosts 10 $native_vlan 113
macro auto built-in parameters ip_phone_desktop $max_hosts 10 $native_vlan 11
macro auto built-in parameters switch $native_vlan 11
macro auto built-in parameters router $native_vlan 11
macro auto built-in parameters ap $native_vlan 11
Actually have been able to resolve the issue by the global command no lldp run and interface lldp med disable command.
