Rack Mount Kit for SG100-24 Switch
Dennis Pillow
Does anyone have any idea where I can get the mounting ears for a Cisco SG100-24 switch. I have two of these with the ears missing from both.
Mark Bracking
You can buy them on Amazon I bought a second SG200-18 that did not come rack mount kit so anyway I bought my their the same ones well work for your switch. Here is link you might be able to use the information in the item to find the for less.
Cisco SF/SG Switch Series OEM 1U Heavy Rack Mount Kit
http://www.amazon.com/Cisco-Switch-Heavy-Rack-Mount/dp/B00XH175YI/ref=sr_1_4?ie=UTF8&qid=1443381693&sr=8-4&keywords=cisco+sg200-26
Mark Bracking
Dennis Pillow
Thanks for the information. That is just what I need.
The original brackets are not an orderable item within Cisco. Usually most vendors will have 3rd party brackets, ranging in different sizes as stated above.
Under certain conditions, Cisco can possibly provide a replacement set.
It would be worth it to call in and open a case with one of the engineers and try that first. Call 1-866-606-1866 to open a case.
If the engineer you reach is unsure, ask them to contact me or the RMA manager and we can assist them.
Eric Moyers
.:|:.:|:. CISCO | Cisco Presales Technical Support | Wireless Subject Matter Expert
Please rate helpful Posts and Let others know when your Question has been answered.
Hi Eric,
Just a follow up question on this, since there's already a replacement model for SG100 which is SG110-16-NA, does the new one come with wide (L) mounting bracket already so we can mount it on standard Data Centre racks? Or it is sold separately with 3rd party bracket? Thanks.
