10-04-2021 09:21 PM
Anybody can assist with the set-up reconfiguration of switch after installing new internet provider.
10-05-2021 12:34 AM
Hi, you should connect devices as below. and make sure users are have correct IP addresses (DHCP or static). ISP router need to do NAT because SG200 do not doing NAT.
Internet ---- ISP router ---- Switch ----- Users
Rate this answer and mark as answer if this solved your concern
10-05-2021 05:33 AM
Can you elaborate re-configuration, if this is just actinve as Layer 2 switch
Connect your ISP router to one of the port and device to another port show work as epected.
