Replacement SG102 Rackmount Bracket
get2square1
Can't locate replacement brackets for an SG102-24 Switch. We initially used it as a desktop device, but now need to mount it in our server rack. I called CISCO Support and they basically told me to purchase a new unit. Does anyone know where I can purchase a new set?
chrebert
Level 4
Level 4
Hello Scott,
When you spoke with support did you get a case number?  If so could you post that or PM me and I will take a look at getting you some replacement brackets.
Christopher Ebert
Senior Network Support Engineer - Cisco Small Business Support Center
Sir,
I also have same issue. We originally intended to use our SG-102 as a desktop unit and now need the ability to mount it in a rack. We can't find our mounting brackets. Can you assist?
