Routing in SG500-52
verdura
Hi all,
I want to permit several VLAN reach internet but can't with the setup (maybe poorly!) I designed. Here goes...
I have 3 VLANs to do InterVLAN routing in a switch Layer 3 and for reach the internet with gateway. My problem is the L3 switch that don't route to a gateway and do it to another. Here are some o the configs (try to minimize not to give you all much trouble!):
SWITCH L3
set system mode router queues-mode 4
interface vlan 100
name FORMACAO
ip address 192.168.100.50 255.255.255.0
ip dhcp relay enable
interface vlan 110
name OPERACOES
ip address 192.168.110.50 255.255.255.0
interface vlan 120
name SERVIDORES
ip address 192.168.200.50 255.255.255.0
interface gigabitethernet1/1/18
description "GW UBIQUITI"
switchport trunk allowed vlan add 100,110,120,400,500
interface gigabitethernet1/1/48
description IPBRICK
ip source-guard
switchport mode access
switchport access vlan 120
ip default-gateway 172.30.1.254
The default gateway 172.30.1.254 is on "gigabitethernet1/1/18" and if I change to "ip default-gateway 192.168.200.254" all works fine (port "gigabitethernet1/1/48" ).
Some more info within switch:
SW-RT-Servidores#sh ip route
Maximum Parallel Paths: 1 (1 after reset)
IP Forwarding: enabled
Codes: > - best, C - connected, S - static
S 0.0.0.0/0 [1/1] via 172.30.1.254, 00:01:21, vlan 400
S 10.0.0.0/8 [1/1] via 192.168.200.254, 195:30:49, vlan 120
C 172.16.0.0/16 is directly connected, vlan 500
C 172.30.1.252/30 is directly connected, vlan 400
C 192.168.1.0/24 is directly connected, vlan 1
C 192.168.100.0/24 is directly connected, vlan 100
C 192.168.110.0/24 is directly connected, vlan 110
C 192.168.200.0/24 is directly connected, vlan 120
SW-RT-Servidores#traceroute ip 8.8.8.8
Tracing the route to google-public-dns-a.google.com (8.8.8.8) from , 30 hops max, 18 byte packets
Type Esc to abort.
1 172.30.1.254 (172.30.1.254) <20 ms <80 ms <20 ms
2 192.168.254.250 (192.168.254.250) <20 ms <20 ms <20 ms
3 xxxx-79-85-21.static.net.xxxx.pt (xxx.79.85.21) <20 ms <20 ms <20 ms
4 10.255.48.82 (10.255.48.82) <20 ms <20 ms
Trace aborted.
Here are more configs from different equipments. From a PC with gw to the switch:
tracert 8.8.8.8
1 2 ms 3 ms 4 ms 192.168.100.50
2 * * * O pedido excedeu o tempo.
3 * * * O pedido excedeu o tempo.
but if I change to "ip default-gateway 192.168.200.254" all works fine!
tracert 8.8.8.8
1 1 ms 4 ms 4 ms 192.168.100.50
2 1 ms <1 ms <1 ms proxy.cinel.ufp [192.168.200.254]
3 1 ms <1 ms <1 ms 192.168.254.250
4 2 ms 2 ms 2 ms xxxx-79-85-21.static.net.xxxx.pt [xxx.79.85.21]
5 7 ms 6 ms 6 ms 10.255.48.82
6 6 ms 6 ms 6 ms xx.14.xx.210
the ip routing table from the default gateway 172.30.1.254:
admin@GATEWAY:~$ show ip route
Codes: K - kernel route, C - connected, S - static, R - RIP, O - OSPF,
I - ISIS, B - BGP, > - selected route, * - FIB route
S>* 0.0.0.0/0 [1/0] via 192.168.254.250, eth2
C>* 127.0.0.0/8 is directly connected, lo
C>* 172.16.0.0/16 is directly connected, eth0.500
C>* 172.30.1.252/30 is directly connected, eth0.400
C>* 192.168.1.0/24 is directly connected, eth0
C>* 192.168.100.0/24 is directly connected, eth0.100
C>* 192.168.110.0/24 is directly connected, eth0.110
C>* 192.168.200.0/24 is directly connected, eth0.120
C>* 192.168.254.0/24 is directly connected, eth2
To my knowledge all should worked but...
Can you guys please put me in the right path?
Thanks and if you need more configs tell me please!
mipopov
Hello Verdura,
Try to assign the IP to VLAN 400 from 172.30.1.252/30 network.
What happens?
Cheers,
Mike
I already have done it:
interface vlan 100
name FORMACAO
interface vlan 110
name OPERACOES
interface vlan 120
name SERVIDORES
interface vlan 400
name SW-GW
ip address 172.30.1.253 255.255.255.252
