09-13-2018 04:53 PM
We have two SG550XG switches configured with RSTP connected to our core switch and convergence time on the native VLAN 1 is within the expected duration. However, a second VLAN 21 on the switch is behaving odd. When the connection to the root is removed we lose one ping, as expected, but when that connection is restored we lose 5-6 ping responses. If the port is set back to native VLAN 1 we lose one ping on the disconnect and one on the reconnect. The issue with VLAN 21 occurs regardless of whether the interface is trunk or access. From what I can tell the packets are dropping during the Listening/Learning phase during re-convergence as opposed to forwarding on the alternate path. Once te1/0/21 (primary uplink) returns to a forwarding state VLAN 21 begins to communicate again. Configuration of the uplink ports below.
09-13-2018 04:54 PM
MDF-SG550-102#sh span te1/0/21
Port te1/0/21 enabled
State: forwarding Role: root
Port id: 128.21 Port cost: 2000
Type: P2P (configured:Auto ) RSTP Port Fast: No (configured:Auto)
Designated bridge Priority : 8193 Address: b4:14:89:61:b2:80
Designated port id: 128.272 Designated path cost: 0
Guard root: Disabled BPDU guard: Disabled
Number of transitions to forwarding state: 1
BPDU: sent 38, received 4701
MDF-SG550-102#sh span te1/0/22
Port te1/0/22 enabled
State: forwarding Role: designated
Port id: 128.22 Port cost: 2000
Designated bridge Priority : 36864 Address: 00:8e:73:ca:41:db
Designated port id: 128.22 Designated path cost: 2000
Number of transitions to forwarding state: 7
BPDU: sent 4712, received 75
MDF-SG550-102#sh run int te1/0/21
interface TengigabitEthernet1/0/21
switchport mode trunk
MDF-SG550-102#sh run int te1/0/22
interface TengigabitEthernet1/0/22
09-17-2018 11:09 AM
