Switches - Small Business
Elevate your network performance with our selection of switches specifically designed for small businesses. Supported model families: CBS, SG, SF, SX
Get 20% off switches when you combine Cisco solutions
We are approaching our latest step in relabelling posts across the Small Business board. 1 week from today, read-only mode will be active on this discussion board from June 18th - July 18th. These dates are subject to change pending progress. This in...
CoreyP319 by Cisco Employee
  • 128 Views
  • 0 replies
  • 1 Helpful votes
  (Updated September 2023 - Added Catalyst 1200 and Catalyst 1300 ) Hello! This sticky-post will serve as a sign-post for incoming community members. Below you will find links to pages that you may find helpful.  Catalyst 1200 & 1300 Hardware Install...
  • 5489 Views
  • 1 replies
  • 16 Helpful votes
I tried to set up an RV320 using 172.30.2.0/24 on the LAN - which is in the private address range of 172.16.0.0 – 172.31.255.255 I got the impression that it didn't or wouldn't work as I'd tried it more than once. Using 192.168.111.0/24 did work righ...
Hello,I have a network where by I have been given a LAN block 66.157.179.160/252 and serial IP by my ISP.  I have successfully configured one of the 550 ports with the correct serial IP addr and gave a default route to the remote serial IP so from th...
HiI have switch SG300-28. Before update firmware i had versdion 1.3.6 and on this fw was option to copy running config to backup....Also on 1.4.7.6 it looks like: Now i update firmware to 1.4.9.4 and boot 1.3.5.06 and this option was removed ?look as...
pepeEL by Level 1
  • 880 Views
  • 1 replies
HiI have a switch sg300-28 without fan and not show temp. I see that in motherboard is point to solder plug for fans and I test and it give on one pin 12V and on second about 3.3V.Is any chance to solder plug and connect fan. It works ok but in GUI n...
pepeEL by Level 1
  • 3102 Views
  • 7 replies
Switch products supported in this community
Cisco Business Product Family
  • CBS110
  • CBS220
  • CBS250
  • CBS350
Cisco Switching Product Family
  • 110
  • 200
  • 220
  • 250
  • 300
  • 350
  • 350X
  • 550X
Top Solution Authors
