Setting the SSL certificate for the web ui
Dirk Dittert
How can I set the SSL certificate for the management interface of an SG300? I don't seem to find the configuration option in the web gui?
Hello Dirk,
To import/ create/ modify ssl ceritificate please go to ' 'Security > SSL Server > SSL Server Authentication Settings'.
HTTPS is enabled by default.
Thanks and regards,
Siva
5 Replies 5
Hello Dirk,
Thanks and regards,
Siva
there is no option "SSL Server" under Security. HTTPS is enabled in TCP/UDP Services.
Hello Dirk,
Kindly provide the product family and firmware version installed. I tested in my lab with SG300-24MP (firmware v1.2.9.44). Options are there...  'Security > SSL Server'..
Thanks and regards,
Siva
Hi Dirk, on the 1.2.7.76 firmware, please reference this screen shot. If you haven't already, ensure you're on the 1.2.7.76 firmware.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Thanks. I'm still on 1.1.2.0 (SG300-52), that's why I am probably not seeing it.I'll try updating the firmware and report if I still have problems.
