SGE2010P TFTP-C-OPEN No free UDP port
fcambria83
I have several switches in SGE2010P stack configuration. As network administrator I proceeded to write a script that updates at regular intervals ACLs on the switch by sending the instruction file via TFTP. I noticed that after about 100 updates, the switch returns me the following error:
% TFTP-C-OPEN: No free UDP port
% COPY-W-TRAP: The copy operation has failed
Copy: Can not open TFTP client
and in order to re-enable the service I required to restart the switch.
Browsing the forums I found that this problem also occurs on a switch alcatel similar. On that switch a firmware update has fixed the bug.
My question is, is there a firmware update for my device that fixes the bug? For your information my current version is 3.0.18
Francesco Cambria
10 Replies 10
Tom Watts
Hi Francesco, the only time I've seen these errors is because the TFTP is being used by another service on your LAN.
If you check the netstats of your machine you should be able to see what is occupying the TFTP service.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
I can guarantee that even rebooting the host on which I listen to the tftp server the problem persists.
This is the description of a bugfix Alcatel relative to a switch similar:
"General
Alcatel 0000530/Alcatel PR 136097/CQ 117,372 (Version 1.7.0.23)
No free UDP port error When copying startup-config tftp of up to ~ 100 times
Status: This issue was fixed "
Francesco
These switches have been around forever. A bug on a different vendor product is a bug on a different vendor's product. Does it mean it is impossible? No, it doesn't.
A reboot of the requesting does not really mean much. It can be a service hosted locally or the TFTP being busy or something else.
You're reaching out for help, I'd like to think you are willing to investigate your avenues.  You are at an impasse and don't have the answer for yourself. If you're looking for affirmation if there is a bug, I can affirm there is not a known bug, nor has been. Not to mention the age of the switch would also reveal such.
Rejecting help doesn't do you or anyone else any good. Even if you feel like you're going backwards, no one has looked at your stuff. No one is at your location. No one knows your problem without you giving all information. And you will lose a lot more time not telling people everything you have done and showing your work to prove it.
If you want to get things done and don't want the input of a public forum, then call the small business support center.
-Tom
I checked the functionality of the tftp server installed on my host using a client in another machine.
Nevertheless, the tftp client of the switch continues to give me back the same error when I try to copy the configuration from the TFTP server to the running-config.
I did not mean in any way fault the service or your work.
If there is anything I can do or information I can find to facilitate troubleshooting, I will gladly give them to you.
Francesco
Can you post a picture of
netstat -a   from the machine in question and also from the tftp
-Tom
here's the server tftp netstat -a :
Active Internet connections (servers and established)
Proto Recv-Q Send-Q Local Address           Foreign Address         State
tcp        0      0 Webserver1:7777         *:*                     LISTEN
tcp        0      0 *:mysql                 *:*                     LISTEN
tcp        0      0 *:www                   *:*                     LISTEN
tcp        0      0 *:ssh                   *:*                     LISTEN
tcp        0      0 Webserver1:www          192.168.21.253:53714    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54935    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54921    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54891    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53704    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54925    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53718    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54899    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53740    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53744    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54939    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54915    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53732    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53736    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53724    TIME_WAIT
tcp        0     52 Webserver1:ssh          192.168.21.250:23659    ESTABLISHED
tcp        0      0 Webserver1:www          192.168.21.253:53730    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54927    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53712    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54893    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54903    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53728    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53710    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54945    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53726    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53742    TIME_WAIT
tcp        0      0 Webserver1:7777         WebServer2:34422        ESTABLISHED
tcp        0      0 Webserver1:www          192.168.21.253:53716    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54917    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54909    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54901    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54929    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53696    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53734    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53748    TIME_WAIT
tcp        0      0 Webserver1:57635        10.0.0.9:mysql          TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54911    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54905    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53720    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54931    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54907    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53722    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54947    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54913    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53746    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53752    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53738    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54943    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54897    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54937    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54923    TIME_WAIT
tcp        0      0 Webserver1:mysql        WebServer2:48778        ESTABLISHED
tcp        0      0 Webserver1:www          192.168.21.252:54933    TIME_WAIT
tcp        0      0 Webserver1:58443        WebServer2:mysql        ESTABLISHED
tcp        0      0 Webserver1:www          192.168.21.253:53706    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54941    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53708    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53698    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53750    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54895    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.252:54919    TIME_WAIT
tcp        0      0 Webserver1:www          192.168.21.253:53700    TIME_WAIT
tcp        0      0 Webserver1:7789         WebServer2:43843        ESTABLISHED
tcp        0      0 Webserver1:www          192.168.21.253:53702    TIME_WAIT
tcp        0      0 Webserver1:40550        WebServer2:7789         ESTABLISHED
tcp6       0      0 localhost:8005          [::]:*                  LISTEN
tcp6       0      0 [::]:http-alt           [::]:*                  LISTEN
tcp6       0      0 [::]:ssh                [::]:*                  LISTEN
udp        0      0 *:tftp                  *:*
udp        0      0 *:694                   *:*
udp        0      0 *:694                   *:*
udp        0      0 *:37594                 *:*
udp        0      0 *:58623                 *:*
raw        0      0 *:icmp                  *:*                     7
Active UNIX domain sockets (servers and established)
Proto RefCnt Flags       Type       State         I-Node   Path
unix  6      [ ]         DGRAM                    6701     /dev/log
unix  2      [ ACC ]     STREAM     LISTENING     9273     /var/run/heartbeat/register
unix  2      [ ACC ]     STREAM     LISTENING     6508     @/com/ubuntu/upstart
unix  2      [ ACC ]     SEQPACKET  LISTENING     7340     @/org/kernel/udev/udevd
unix  2      [ ACC ]     STREAM     LISTENING     6801     /var/run/mysqld/mysqld.sock
unix  2      [ ACC ]     STREAM     LISTENING     6782     /var/lib/heartbeat/log_daemon
unix  2      [ ]         DGRAM                    28243
unix  3      [ ]         STREAM     CONNECTED     9277     /var/run/heartbeat/register
unix  3      [ ]         STREAM     CONNECTED     9276
unix  2      [ ]         DGRAM                    9275
unix  3      [ ]         STREAM     CONNECTED     9227
unix  3      [ ]         STREAM     CONNECTED     9226
unix  3      [ ]         STREAM     CONNECTED     9225
unix  3      [ ]         STREAM     CONNECTED     9224
unix  3      [ ]         STREAM     CONNECTED     9222
unix  3      [ ]         STREAM     CONNECTED     9221
unix  3      [ ]         STREAM     CONNECTED     9220
unix  3      [ ]         STREAM     CONNECTED     9219
unix  3      [ ]         STREAM     CONNECTED     7168
unix  3      [ ]         STREAM     CONNECTED     7167
unix  3      [ ]         STREAM     CONNECTED     7166
unix  3      [ ]         STREAM     CONNECTED     7165
unix  3      [ ]         STREAM     CONNECTED     7162
unix  3      [ ]         STREAM     CONNECTED     7161
unix  2      [ ]         DGRAM                    7157
unix  2      [ ]         DGRAM                    6774
unix  3      [ ]         STREAM     CONNECTED     6773
unix  3      [ ]         STREAM     CONNECTED     6772
unix  3      [ ]         STREAM     CONNECTED     7401     @/com/ubuntu/upstart
unix  3      [ ]         STREAM     CONNECTED     7399
unix  3      [ ]         DGRAM                    2300
unix  3      [ ]         DGRAM                    2299
unix  3      [ ]         STREAM     CONNECTED     2266     @/com/ubuntu/upstart
unix  3      [ ]         STREAM     CONNECTED     6552
Here's the TFTP client netstat -a:
tcp        0      0 WebServer2:7777         *:*                     LISTEN
tcp        0      0 WebServer2:www          192.168.21.252:44285    TIME_WAIT
tcp        0      0 WebServer2:33987        192.168.21.250:5038     ESTABLISHED
tcp        0      0 WebServer2:www          192.168.21.252:44283    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44247    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44291    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44289    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44245    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48359    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44273    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48355    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44241    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44281    TIME_WAIT
tcp        0      0 WebServer2:43843        Webserver1:7789         ESTABLISHED
tcp        0      0 WebServer2:www          192.168.21.253:48305    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44267    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48325    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44261    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48327    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48353    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44259    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44239    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48357    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44295    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48349    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44277    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48321    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44237    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48333    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44257    TIME_WAIT
tcp        0      0 WebServer2:48778        Webserver1:mysql        ESTABLISHED
tcp        0      0 WebServer2:www          192.168.21.253:48331    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44265    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48343    TIME_WAIT
tcp        0      0 10.0.0.6:mysql          10.0.0.5:49164          ESTABLISHED
tcp        0      0 WebServer2:www          192.168.21.253:48335    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48329    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44293    TIME_WAIT
tcp        0      0 WebServer2:ssh          192.168.21.:rmiregistry ESTABLISHED
tcp        0      0 WebServer2:www          192.168.21.253:48323    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48347    TIME_WAIT
tcp        0      0 10.0.0.6:mysql          10.0.0.5:49162          ESTABLISHED
tcp        0      0 WebServer2:www          192.168.21.252:44243    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48315    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44263    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48301    TIME_WAIT
tcp        0      0 WebServer2:7789         Webserver1:40550        ESTABLISHED
tcp        0      0 WebServer2:www          192.168.21.253:48313    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48345    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44255    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44253    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48309    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44269    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48341    TIME_WAIT
tcp        0      0 WebServer2:mysql        Webserver1:37154        ESTABLISHED
tcp        0      0 WebServer2:www          192.168.21.253:48351    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44249    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48319    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44251    TIME_WAIT
tcp        0     52 WebServer2:ssh          192.168.21.250:2648     ESTABLISHED
tcp        0      0 WebServer2:www          192.168.21.253:48337    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48307    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48317    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48303    TIME_WAIT
tcp        0      0 10.0.0.6:mysql          10.0.0.5:52948          ESTABLISHED
tcp        0      0 WebServer2:www          192.168.21.252:44275    TIME_WAIT
tcp        0      0 WebServer2:34422        Webserver1:7777         ESTABLISHED
tcp        0      0 WebServer2:www          192.168.21.253:48339    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44271    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44287    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.252:44279    TIME_WAIT
tcp        0      0 WebServer2:www          192.168.21.253:48311    TIME_WAIT
udp        0      0 *:40993                 *:*
udp        0      0 *:55548                 *:*
udp        0      0 *:694                   *:*
udp        0      0 *:694                   *:*
unix  2      [ ACC ]     STREAM     LISTENING     532      /var/run/mysqld/mysqld.sock
unix  2      [ ACC ]     STREAM     LISTENING     248      @/com/ubuntu/upstart
unix  2      [ ACC ]     STREAM     LISTENING     8384     /var/lib/heartbeat/log_daemon
unix  2      [ ACC ]     SEQPACKET  LISTENING     7446     @/org/kernel/udev/udevd
unix  6      [ ]         DGRAM                    449      /dev/log
unix  2      [ ACC ]     STREAM     LISTENING     7648     /var/run/heartbeat/register
unix  3      [ ]         STREAM     CONNECTED     10985    /var/run/mysqld/mysqld.sock
unix  3      [ ]         STREAM     CONNECTED     8983
unix  2      [ ]         DGRAM                    7677
unix  3      [ ]         STREAM     CONNECTED     7650     /var/run/heartbeat/register
unix  3      [ ]         STREAM     CONNECTED     887
unix  2      [ ]         DGRAM                    886
unix  3      [ ]         STREAM     CONNECTED     2511
unix  3      [ ]         STREAM     CONNECTED     2510
unix  3      [ ]         STREAM     CONNECTED     2509
unix  3      [ ]         STREAM     CONNECTED     2508
unix  3      [ ]         STREAM     CONNECTED     2506
unix  3      [ ]         STREAM     CONNECTED     2505
unix  3      [ ]         STREAM     CONNECTED     2504
unix  3      [ ]         STREAM     CONNECTED     2503
unix  3      [ ]         STREAM     CONNECTED     2500
unix  3      [ ]         STREAM     CONNECTED     2499
unix  3      [ ]         STREAM     CONNECTED     2498
unix  3      [ ]         STREAM     CONNECTED     2497
unix  3      [ ]         STREAM     CONNECTED     2494
unix  3      [ ]         STREAM     CONNECTED     2493
unix  2      [ ]         DGRAM                    2491
unix  2      [ ]         DGRAM                    2408
unix  3      [ ]         STREAM     CONNECTED     2407
unix  3      [ ]         STREAM     CONNECTED     2406
unix  3      [ ]         STREAM     CONNECTED     413      @/com/ubuntu/upstart
unix  3      [ ]         STREAM     CONNECTED     8314
unix  3      [ ]         DGRAM                    7481
unix  3      [ ]         DGRAM                    7480
unix  3      [ ]         STREAM     CONNECTED     293      @/com/ubuntu/upstart
unix  3      [ ]         STREAM     CONNECTED     2133
Thank you.
Francesco
Hi Francesco, when the switch is not able to download from the TFTP server, are you able to load a program such as TFTPD32 and test that on a computer that is locally connected to the switch?
-Tom
Hi Tom,
Of course, I have run this test several times, any client works perfectly.
Francesco
Is there any cpu utilization problems when the switch is not responding to the TFTP? If you disconnect the switch from the network then plug it back in to the network, does it work after?
-Tom
Hi Tom,
I will describe the results for the tests conducted on the use of the CPU. The execution of the procedure for connecting to the server tftp increases the cpu of about 5%.
Will arrange as soon as possible to let you know the results of the other test.
Francesco
