Thank you for using the Cisco Small Business forums. My name is Cristian, I am an eContent developer and I am part of the Small Business Support Community. Unfortunately the SF-200 24FP cannot act as a DHCP server, that is usually reserved for routers and the SF-200 is a switch. The SF-200 does however have the ability to enable the passing of configuration information to hosts via a TCP/IP network. This is called DHCP Auto Configuration. You can see read more about it in the admin guide here: http://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf20x_sg20x/administration_guide/78-21139.pdf
Learn, share, save
