SF200-24FP 24-Port Rebooting
andrewcolosimo
Hi, I'm having an issue with this switch rebooting - around once per day it seems.
The log is pasted below - note, i'm using an LTSP server to PXE boot Thin Clients on the network. I'm not sure if this is causing the reboot as the switch is trying to update from it .. can this be disabled?
21474622052015-Jun-12 16:39:22Informational%INIT-I-Startup: Cold Startup
21474623312015-Jun-12 16:38:52Warning%COPY-W-TRAP: The copy operation has failed, aggregated (1)
21474624872015-Jun-12 16:38:48Alert%TFTP-A-TftpTxERROR: An error message was sent: 0 <Closed by application>, aggregated (1)
21474626882015-Jun-12 16:38:48Informational%COPY-I-FILECPY: Files Copy - source URL tftp://10.5.5.250/ltsp/i386/pxelinux.0 destination URL flash://startup-config, aggregated (1)
21474627982015-Jun-12 16:38:22Warning%COPY-W-TRAP: The copy operation has failed
21474629382015-Jun-12 16:38:19Alert%TFTP-A-TftpTxERROR: An error message was sent: 0 <Closed by application>
21474631232015-Jun-12 16:38:19Informational%COPY-I-FILECPY: Files Copy - source URL tftp://10.5.5.250/ltsp/i386/pxelinux.0 destination URL flash://startup-config
21474632252015-Jun-12 16:38:01Notice%SYSLOG-N-LOGGING: Logging started.
21474634352015-Jun-12 16:37:59Warning%COPY-W-TRAP: The copy operation has failed
21474635752015-Jun-12 16:37:56Alert%TFTP-A-TftpTxERROR: An error message was sent: 0 <Closed by application>
21474637602015-Jun-12 16:37:55Informational%COPY-I-FILECPY: Files Copy - source URL tftp://10.5.5.250/ltsp/i386/pxelinux.0 destination URL flash://startup-config
21474638732015-Jun-12 16:37:54Warning%STP-W-PORTSTATUS: fa10: STP status Forwarding
21474639862015-Jun-12 16:37:53Warning%STP-W-PORTSTATUS: fa11: STP status Forwarding
21474640992015-Jun-12 16:37:53Warning%STP-W-PORTSTATUS: fa12: STP status Forwarding
21474642122015-Jun-12 16:37:52Warning%STP-W-PORTSTATUS: fa21: STP status Forwarding
Michal Bruncko
Level 4
Level 4
Which way do you use for assigning management IP for switch? It is DHCP or statically assigned?
Michal Bruncko
Level 4
Level 4
Hi and thanks for the reply.
by dhcp but it has a static mapping.
i disabled auto configuration settings and i think the issue has stopped.
Yes, that was I trying to point with disabling DHCP. Normally switches should have manual IP assignment without relaying on DHCP. DHCP is really useful for end-users or maybe printers (with static mapping). But for such core devices like switches, routers or servers I would always prefer manual IP assignment.
So with disabling DHCP IP configuration seems your issue is gone... . For me it looks like bug in firmware and probably it could be subject to report to Cisco in order to get it fixed as it have impact to device stability.
made your answer correct.. been working flawless every since i disable it.. i've also set static ip now as well.
