SF200 port mirroring function
i was able to configure (via SF200 web interface) a port mirroring from port FE17 to FE7.
i have supressed this port mirroring.
when i try to reconfigure a port mirroring from port FE17 to FE3. The SF200 web interface crash. the SF200 seems to reboot.
i have updated the SF200 firmware from V1.1.2.0 to V1.1.2.9.44
when i was able to configure (via SF200 web interface) a port mirroring from port FE17 to FE7.
But  after having suppressed this port mirroring again, i was not able to  reconfigure a new port mirroring from port FE1 to FE3 (the SF200 hangs).
i have also tried to return to default factory setting but this does not solve the issue.
i am working on SF200-24P
Thanks for helping !
Christophe
Tom Watts
Hi Chris, are you connecting the computer to the source port or destination port? When you run the port monitor, the port receiving information (destination) will not function and drop all connectivity).
With that said, when you modified the port mirror, can you move the computer to a completely unrelated port such as fe10 and get connectivity?
Or, if the monitor port is an uplink to such a device as a router, can you move that port connection to something entirely unrelated like port 20 to see if you gain connectivity?
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
Yes you are right Tom!
The port from which i was making the switch management was the destination port i wanted to play with (FE3).
You solve my issue. Thanks.
Christophe
