SF300-24P 24-Port 10/100 PoE Managed Switch
faheem.saeed
I have been using SF300-24P 24-Port  10/100 PoE Managed Switch since 2 years and i never faced any problem, but from last couple of days it is showing orange color blinking light on system. I have restarted the switch but it didn't fix the problem. What could be the reason? How to remove the blinking orange light of system?
Thanks.
ktonev
You can find the meaning of different LED colors in the quick start guide:
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbms/sf30x_sg30x/quick_start/78-19252-01.pdf
In your case an amber system LED means that the system has detected a hardware failure. I recommend calling our support centre so an engineer can assist further in identifying the issue and offering a solution.
Kris
If you found this post useful please rate it so other users can benefit as well.
