SF300-24P POE ERROR
Vanja Maslac
After firmware upgrade from v1.1.2.0 to 1.3.0.62 i get this in terminal console (see attached) ..
Firmware v1.2.7.76 and below works without this error. Firmware 1.2.9.44 and above does not.
Does anyone have any suggestion how to fix this.?
Thnx
Vanja
Tom Watts
Hi Vanjay, this looks like it incremented an error counter then caused the POE function to disable. If it worked on the previous software versions then I'd recommend to call the SBSC for further analysis.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
pzanderson
Hi Vanja,
I also had POE issues after upgrading to the 1.3.0.62 firmware and had to roll back to the older firmware which was very stable.
I don't have the logs anymore, but from memory it was the same error that you are seeing.
Phil
Vanja,
For what it's worth, the POE and other stability issues which kept me on 1.2.7.76 appear to be resolved in 1.3.5.58.  At least they haven't occured after a few days testing.
Phil
