09-14-2016 11:54 AM
I have a 100+ Small Business 300 Switches (different models) out in the field. Firmware versions range from 1.3.7.18 to 1.4.5.02. They are all L2. Recently I started experiencing some of the Switches (random sites) losing their IP, Subnet and Gateway. The rest of the configuration remains intact. The only way to fix it is to go to the site, connect via console cable and re-configure it. I suspected that the SNMP Community String with Read/Write privileges may play a role in this and removed it yet the problem persisted and I ruled it out. I did however remove the Read/Write string on all the devices as it is not being used anymore.
With the SNMP ruled out I suspected possible power issues to the units. I have tried to emulate this problem in our lab by dropping the power to a unit numerous times and powering it up again without success. It powers up fine and the configuration is fine.
Any ideas out there as to what the problem may be?
Andre
Solved! Go to Solution.
11-21-2017 11:49 PM
Morning Michal
My appologies for only replying to your query now.
I think I now know what my problem was with the loss of management IP's on some of the Switches. It seems to have been software related. On all the Switches where I lost my Management IP's, I upgraded the software to versions 1.4.7.06 and more recently to 1.4.8.06. Since then this problem seems to be resolved as I have not encountered the problem again. I am now working through all my Switches to ensure the software is on the latest version.
André
11-16-2016 04:00 AM
We have logged a TAC with Cisco to investigate.
11-21-2016 12:32 AM
11-21-2017 11:49 PM
Morning Michal
André
