SF302-08P Problem -Rapidly blinking green & amber PoE port lights
alex
Hi All,
New on here, having no Cisco problems so far!
I run a SF302-08P to simply power PoE 3 x IP phones in my office. All has been running well with the switch until today, I lost connectivity and all PoE ports are blinking the green and amber lights repeatedly.
I searched Cisco documentation on this switch and couldn't find anything about this specific issue. I'm not experienced but cannot access the IP of the switch/ping it. I've tried to reset 10+ & 30+ seconds on the reset switch, disconnecting all cables.
Any help would be greatly appreciated. Thanks in advance.
Deepak Kumar
Remove all phones and connect a laptop to switch and try to get details as 1) Is switching Uplink is working? 2). Only with Laptop (means Non-POE) is working fine or not?
You can reset the switch as remove all cables (don't remove power cable) and keep pressing the reset button for 10 seconds. The switch will restart.
Deepak Kumar
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
