01-31-2014 09:39 PM
We have seven 300 series small business switches, all consistently configured. All running 1.3.5.58 firmware with 1.3.5.06 boot code.
2x SG300-28P V01
1x SF300-24P V01
1x SF300-48 V01
1x SF300-48P V01
1x SF302-08P V01
1x SF302-08P V02
I have successfully assigned certificates from our Microsoft certificate authority (2008 R2) to five of the units, but can not assign certificates to the two SF302-08Ps.
I use the following commands:
config
crypto certificate 1 generate key-generate 2048
exit
crypto certificate 1 request cn XXX ou XXX or XXX loc XXX st CA cu US
config
crypto certificate 1 import
-----BEGIN CERTIFICATE-----
-----END CERTIFICATE-----
I receive the following error: SSL can't import certificate - conversion of input to certificate failed.
Again, those commands work on five out of seven switches. The only common factor is that they fail on the two small switches. I have tried rebooting immediately before attempting to generate the key and import the certificate. I tried rebooting immediately before attempting to import the certificate on the existing key. I verify all CSRs and certificates with the utilities here: http://www.sslshopper.com/csr-decoder.html and http://www.sslshopper.com/certificate-decoder.html. I've turned with logging buffer up to level 7 (debugging), but no message is recorded.
Any thoughts on why these two switches won't import my Microsoft CA certificates?
02-04-2014 03:24 PM
Sean, could you email me a sample certificate at tmw0402@hotmail.com ?
I'd like to try to reproduce in a lab to see how my switches behave.
-Tom
Please mark answered for helpful posts
02-04-2014 09:28 PM
Tom,
I have sent you a replay of an effort to generate a CSR and import the certificate issued by our CA. Please let me know if you can reproduce.
Sean
05-30-2015 09:01 PM
This seems remarkably similar to my issue: https://supportforums.cisco.com/discussion/12521456/sg300-ssl-certificate-issues-ssl-cant-import-certificate-conversion-input
Did you ever discover what the solution was?
-Zac
