OOB management help
smiller1091
Good afternoon,
I'm working on figuring out why some remote branches cannot be managed by dialing in. The line dials and appears to connect, but in the terminal nothing ever shows up.
The configuration is this:
line 0/3/0
 modem InOut
 transport input all
 stopbits 1
 speed 115200
 flowcontrol hardware
The two bolded statements were missing, and I put them in. I thought this would solve the issue, but it has not. Our configuration seems to be the same on working routers as the configuration above. We are using 2911's with 15.1XXX if that helps.
cchamorr
Level 5
Level 5
I'm sorry you are having issues with your device, unfortunately this is not the right forum for this type of units as it is meant to be used for small business units only.
You can try moving it to the following section: https://supportforums.cisco.com/community/5716/voice-over-ip
I hope this helps.
Try this link
http://www.cisco.com/en/US/docs/internetworking/troubleshooting/guide/tr1916.html
Alex
Regards, Alex. Please rate useful posts.
