12-01-2010 08:23 AM
Hi everyone,
Is possible configure broadcast limites by port in SFE2000?
Thanks.
Solved! Go to Solution.
12-03-2010 01:20 AM
Hi Andre,
Yes you have the option to set on a per interface basis the broadcast and multicast packet storm control, see my screen capture below from the SFE2000 big brother the SGE2000P. The operating system is basically the same on the SGE2000 and the SFE2000.
if you have rate limiting already set on a interface it will take precedence over the broadcast rate limits that you set.
regards Dave
12-03-2010 01:20 AM
Hi Andre,
regards Dave
12-03-2010 02:39 AM
Thanks David.
