12-02-2010 05:54 AM
hi guys,
I have got a switch SRW224G4P that doesn't work.
Connecting by HyperTerminal this message appears:
Image Loader 1.0.1
Loading Diagnostic Image File : SRW224G4P_SRW248G4P_boot.bix
Diagnostic 1.0.1
User Mode
--- Performing Power-On Self Tests (POST) ---
DUMMY Test 1 ................. PASS
UART Loopback Test ........... PASS
POE UART Loopback Test ....... PASS
DRAM Test .................... PASS
Timer Test ................... PASS
Done All Pass.
------------------ DONE ---------------------
(!)Loader Binary checksum error
Loading Runtime Image File : SRW224G4P_SRW248G4P_image.bix
FS_ReadFileContent::Warning!! Read file SRW224G4P_SRW248G4P_image.bix with the c
heck sum error. The block 55 on unit -1 will be erased automatically.
I tried to enter with CTRL+U for deleting the file and replace the file downloading from website.
Image Loader 1.0.1
File Name S/Up Type Size Create Time
$logfile_1 0 3 64 1193046:28:15
Factory_Default_Config.cfg 0 5 354 24:00:48
SRW224G4P_SRW248G4P_boot.bix 1 1 1377600 00:01:03
SRW224G4P_SRW248G4P_image.bix 1 2 3752968 25:06:45
certificate 0 8 18040 24:00:42
startup-config 1 5 3582 76840:58:57
startup1.cfg 0 5 3376 24:01:00
Free Space : 1835008
[X]modem Download [D]elete File [S]et Startup File
[Q]uit
Select>
File name to delete : SRW224G4P_SRW248G4P_image.bix
This is starup file, you sure you want to delete it (y/n) ?y
But the switch doesn't delete the file and remain locked with this screen...
Please, some one can help me?
Thank in advance,
Luciano
12-03-2010 01:11 AM
Hi Luciano
Obviously not a normal operation that you are experiencing.
Just looking at the output, it seems like a Flash memory error issue with loading of the Operating system file .bix extension.
Dare i suggest that either you can be sure that your console setting are correct according to the Administrators guide.
If you can't download via X-modem the .bix firmware file that will overwrite the old file, I would suggest you contact the SBSC and avail yourself of the 5 year Warranty on those switches.
I can only apologise that you are in this situation, I'm sure SBSC will either help you fix the situation or replace the product.
Contact the Small Business Support center via the following URL to get warranty support within your country.
http://www.cisco.com/en/US/support/tsd_cisco_small_business_support_center_contacts.html
regards Dave
12-03-2010 08:23 AM
Thank you for the reply.
The COM1 has been set right and the downloading via x-modem seems not work... therefore I followed you suggestion: RMA has been open. Next Monday I'll send back the switch to CISCO for replacement.
Thanks a lot for your interesting.
Regards, Luciano
