SG 200-08 All LED lights flashing green after power failure
sg208xxxx
Thinking back, about a month ago I updated the firmware (sorry I can't check version at the moment). The switch has been working fine since then. Today I needed to move some power cables and the switch lost power. Now ALL of the LED lights are flashing green and I can't access the switch. I've tried setting a static IP on my laptop to 192.168.1.20, mask 255.255.255.0, and accessing the switch on 192.168.1.254, but there's no response. I've tried holding in the reset button for at least 30 seconds while the switch is powered on, AND while powering it on. None of that has worked. Also when I first power it on, the system LED flashes orange very quickly for a second or so, then all of the LEDS start flashing green.
What am I missing?
6 Replies 6
sg208xxxx
Ok, I finally made some progress and got this screen below. If I can locate where I downloaded the previous firmware I think I can get this going again.
Ok, seems to be working normally again now!
Installed Firmware SG200-08x Firmware Version 1.0.3.3
paul.sheehan
Hi Ryan;
Could I ask how you reset or broke into the switch since I hava verysimilar situation.
Paul
Hi Ryan;
Berg
sg208xxxx
Its been a few months, so I don't remember the details, but I think it was a combination of using the reset button and then opening a browser to the default IP address. If you look at the screenshot I posted it has the IP address I used. I downloaded the firmware again and the webpage in the screenshot is where the router is asking me for the location of the firmware I downloaded. After it finished reloading the firmware it worked again.
connect with an interface manually set to 192.168.1.253 directly to the router with the blinking leds. Navigate to 192.168.1.254 and you should get a firmware recovery screen. Simply point to an applicable firmware file and reload it.
