SG 300 L3 routing problem
I still have a problem on routing of sg300 L3
Can someone help me on this
User Name:cisco
Password:*****
SOW#sh run
config-file-header
SOW
v1.3.0.62 / R750_NIK_1_3_647_260
CLI v1.0
set system mode router
file SSD indicator encrypted
ssd-control-start
ssd config
ssd file passphrase control unrestricted
no ssd file integrity control
ssd-control-end cb0a3fdb1f3a1af4e4430033719968c0
vlan database
vlan 10-15
exit
voice vlan oui-table add 0001e3 Siemens_AG_phone________
voice vlan oui-table add 00036b Cisco_phone_____________
voice vlan oui-table add 00096e Avaya___________________
voice vlan oui-table add 000fe2 H3C_Aolynk______________
voice vlan oui-table add 0060b9 Philips_and_NEC_AG_phone
voice vlan oui-table add 00d01e Pingtel_phone___________
voice vlan oui-table add 00e075 Polycom/Veritel_phone___
voice vlan oui-table add 00e0bb 3Com_phone______________
ip dhcp server
ip dhcp pool network vlan-10
address low 10.1.10.1 high 10.1.10.254 255.255.255.0
default-router 10.1.10.1
dns-server 212.77.192.59 212.77.192.60
exit
ip dhcp pool network vlan-11
address low 10.1.11.1 high 10.1.11.254 255.255.255.0
default-router 10.1.11.1
exit
ip dhcp pool network vlan-12
address low 10.1.12.1 high 10.1.12.254 255.255.255.0
default-router 10.1.12.1
exit
ip dhcp pool network vlan-13
address low 10.1.13.1 high 10.1.13.254 255.255.255.0
default-router 10.1.13.1
exit
ip dhcp pool network vlan-14
address low 10.1.14.1 high 10.1.14.254 255.255.255.0
default-router 10.1.14.1
exit
ip dhcp pool network vlan-15
address low 10.1.15.1 high 10.1.15.254 255.255.255.0
default-router 10.1.15.1
exit
bonjour interface range vlan 1
ip access-list extended 1
permit ip any any
exit
hostname SOW
no passwords complexity enable
ip telnet server
interface vlan 1
 ip address 1.1.1.1 255.255.255.0
 no ip address dhcp
interface vlan 10
 name vlan-10
 ip address 10.1.10.1 255.255.255.0
interface vlan 11
 name vlan-11
 ip address 10.1.11.1 255.255.255.0
interface vlan 12
 name vlan-12
 ip address 10.1.12.1 255.255.255.0
interface vlan 13
 name vlan-13
 ip address 10.1.13.1 255.255.255.0
interface vlan 14
 name vlan-14
 ip address 10.1.14.1 255.255.255.0
interface vlan 15
 name vlan-15
 ip address 10.1.15.1 255.255.255.0
interface gigabitethernet1
 switchport mode access
 switchport access vlan 10
interface gigabitethernet2
 switchport access vlan 11
interface gigabitethernet3
 switchport access vlan 12
interface gigabitethernet4
 switchport access vlan 13
interface gigabitethernet5
 switchport access vlan 14
interface gigabitethernet6
 switchport access vlan 15
interface gigabitethernet7
interface gigabitethernet8
interface gigabitethernet10
 ip address 10.1.1.2 255.255.255.0
 storm-control broadcast enable
 storm-control broadcast level 10
 spanning-tree link-type point-to-point
 service-acl input 1 default-action permit-any
 switchport trunk allowed vlan add 10-15
 macro description router
 macro auto smartport type router $native_vlan 1
exit
ip default-gateway 10.1.1.1
SOW#
6 Replies 6
Charles Hill
Hello Rodante Evangelista,
Do a show ip int brief, please and post the output.
Are all your vlans up?
Hope this helps,
Please rate helpful posts.
Thanks.
SOW#show ip interface
  GigabitEthernet      IEEE 802.3 Gigabit Ethernet port id
  GE                   IEEE 802.3 Gigabit Ethernet port id
  Port-Channel         Valid Port-Channel interface.
  vlan                 Valid VLAN interface.
   <CR>
SOW#show ip interface ge 10
    IP Address         Type     Directed   Precedence   Status
                                Broadcast
10.1.1.2/24         Static      disable    No         Valid
Take a look at this posting.  It discusses setting up routing on a sg300 router.
https://supportforums.cisco.com/discussion/11520346/cisco-sg300-10-how-set-inter-vlan-routing
hope this helps,
please rate helpful posts
thanks
devils_advocate
Level 7
Level 7
It would be helpful to know what the actual problem is.
"I still have a problem on routing of sg300 L3"
This doesn't really tell us what the issue is.
Its like taking your car into a garage and simply saying, 'I have a problem, please fix it'
If you have sg300 you can help but if you dont you cannot.
as stated "SG 300 L3 routing problem"
so what do you think
I need a complete routing for sg300
if you have a running config of sg it is better because it is proven.
thanks
I have an SG300 and have set plenty up but based on your attitude, I no longer wish to help.
Good luck.
