05-18-2020 11:00 AM
I bought a SG110-16 and I am trying to connect my uVerse router via Ethernet cable to the switch, it does not light up any indicators. If I put the same ethernet cable into my old netgear switch it works as expected, lighting up the port. Is there a specific port that I need to use on the SG110-16 so that the router connection will light up? Any ideas why it wouldn't work in the SG110-16 but it works fine in the old netgear switch?
05-19-2020 12:06 AM
- What's the particular port-configuration ?
M.
05-19-2020 07:33 AM
It is an unmanaged switch, so plug and play. It is supposed to auto detect.
05-20-2020 03:01 AM
- Is there any info/errors being reported on the uverse side ?
M.
05-31-2020 10:17 AM
Whether you are facing this issue for all the switch ports in SG110-16 switch? If you connect any PC /Laptop on the SG110-16 switch port, whether that works as expected? You may check once by changing the Ethernet cable.
05-31-2020 07:58 PM
