05-25-2017 07:29 AM
I need a replacement power supply for a SG200-08P switch. The power supply is the one that has the 4 pins on the barrel connector. I found a similar post from 3 years ago with the same problem, but the contact email that was given is no longer valid. Any help would be appreciated.
05-29-2017 05:12 AM
My name is Kristian and I am one of the engineers from the Small Business team.
As per the message below the power supply for these devices is covered under 1 year limited warranty. If your device is still entitled under warranty you can give us a call and we will open a support case.
Limited lifetime warranty: The Cisco 200 Series switches come with the Cisco Limited Lifetime Hardware Warranty, with return-to-factory replacement, a 1-year limited warranty for fans and power supplies, and a 90-day limited software warranty.
Kris
04-12-2019 05:44 AM
it's nice that you can help us if our power supply still has warranty. But what do we do if not?
I have a switch here and I simply don't have the power supply.
Can you tell me where I can get a spare?
Our switch was purchased via an online platform. That was several years ago.
However, somebody lost the power supply.
