04-12-2019 08:11 PM
I want to enable SPAN port on the SG300-288PP switch, However, when I tied to enable SPAN, I get the following error message but I don't have Port Security configure neither the source interface (Gi4) nor the destination interface (GI24). Is this a bug on the version? Or I have other ports configured with Port Security feature. Is this a problem?
===Error
SQM-SG300(config)#int gi24
SQM-SG300(config-if)#port monitor gi4
Port gi24: Lock port Dynamic Enable prevents executing Copy Port Enable
===SPAN source Interface
SQM-SG300#show run int gi4
interface gigabitethernet4
storm-control broadcast enable
storm-control broadcast level 10
storm-control include-multicast
spanning-tree portfast
macro description ip_phone
switchport trunk allowed vlan add 150
!next command is internal.
macro auto smartport dynamic_type ip_phone
===SPAN destination Interface
SQM-SG300#show run int gi24
interface gigabitethernet24
===Other port
interface gigabitethernet1
port security max 10
port security mode max-addresses
port security discard trap 60
===Version
SQM-SG300(config-if)#do show version
SW version 1.4.8.6 ( date 10-Jul-2017 time 17:14:12 )
Boot version 1.3.5.06 ( date 21-Jul-2013 time 15:12:10 )
HW version V03
04-12-2019 08:27 PM
04-12-2019 08:45 PM
Update:
I tried the followings but no luck. Now I have a feeling this version or model doesn't support the SPAN. Anyone configure SPAN on SG300-28PP?
1. I removed all port security confng from all ports
2. I removed all config on the destination port gi24
3. However, I still get the same error "Lock port Dynamic Enable prevents executing Copy Port Enable"
no spanning-tree portfast
04-12-2019 09:34 PM
Disable macro auto smartport under the interface. i.e. "no macro auto smartport"
04-13-2019 09:11 AM
Thank you for the suggestion. Still doesn't work... I am not sure what I can do next.
==Source Port
==Destination port
==Error
SQM-SG300(config-if)#port monitor GigabitEthernet 4
04-13-2019 10:08 AM
Hi @tnakano03 ,
Could you share the full result of the command show interface giga 24 and show interface giga 4?
