sg200-26P RESET
IonCosmin85272
i tried to reset the switch but the switch won t reset no matter how long i press the reset buton. This problem appeared after i tried to reset it, the leds all lead up and staid like that for about 1 minute after witch i cut the power. now i cant connect to it no mater what i trie.
balaji.bandi
Try hold for reset 30 Seconds as part of reset process.
Give some time to reset process take place ( make sure not other ports connected) while doing reset.
https://community.cisco.com/t5/small-business-switches/how-to-set-sg200-08p-to-factory-default-settings/td-p/1761791
BB
Sujoy Paria
Are you able to observe any physical damage on the reset button or the button is broken?
