SG200-26P Setup VLAN newbie question
FBorjahns
Dear all,
after using a Netgear switch for years, this is my first Cisco switch now and it is driving me crazy as it is far more "professional" than the Netgear one...
My question is:
From my router I am connected to the switch with two separate interfaces that should work as two "zones". GE25 is for LAN, GE26 is for WLAN.
Now I have connected my
  • LAN devices to ports GE4 to GE24
  • WLAN devices to ports GE1 to GE3
How do I have to setup the VLANs so that the port groups mentioned above do not see each other?
You may assume that I would like to use VLAN IDs
  • 10 for LAN
  • 100 for WLAN
Any help is being appreciated. Thank you.
Best regards,
Frank
jeffrrod
Level 4
Level 4
Dear Frank,
Thank you for reaching the Small Business Support Community.
Notice the SG200 is a Layer2 device and therefore does not provide inter-VLAN communication by its own.  Please refer to the below article "VLAN configuration on SG200 managed switches";
http://sbkb.cisco.com/CiscoSB/Loginr.aspx?login=1&pid=2&app=search&vw=1&articleid=80
I hope you find this information helpful and please do not hesitate to reach me back if there is any further assistance I may help you with.
Kind regards,
Jeffrey Rodriguez S. .:|:.:|:.
Cisco Customer Support Engineer
*Please rate the Post so other will know when an answer has been found.
Jeffrey Rodriguez S. .:|:.:|:. Cisco Customer Support Engineer *Please rate the Post so other will know when an answer has been found.
jeffrrod
Level 4
Level 4
Dear Frank,
Kind regards,
Thank you for your hint, Jeffrey
