SG200-26P web gui freeze down during configuration
blasemarzo
I bought this switch to my homelab to merge gigabit and poe into 1 switch. As it was second hand, I restored the factory default, read the manual, but it doesn't work at the very begining. I'm able to make new vlans, but they aren't enabled even if I click in it. I'm unable to use the Port to Vlan and Port Vlan membership function, whatever I choose (access or trunk) it starts thinking and never finish the confirmation. It completely freezes, I just can reboot the device. Obviously when it reboots the intended changes never happened. I tried at least 4 different firmware, all the browsers (Chrome, Firefox, Internet Explorer, Edge). Does anyone have idea what should I do with this? It wasn't a fortune so mainly I'm angry about wasting my space in the rack, as it is completely useless in this state.
9 Replies 9
marce1000
  - Make sure to use the latest firmware available ,
 M.
When I bought it I updated it to the latest one. It was the same. Since then I tried to more 14 and 2 13 version and all the same.
          - Check logs on the device when trying to configure ,
 M.
Flash Memory Log TableLog Index Log Time Severity Description
21474834752014-Jan-12 17:29:12Error%HTTP_HTTPS-E-GOHDHTTPFTHISIDX: GOAHEADG: missing HTTP file transfer mandatory Data.
21474836472020-Apr-08 12:55:22Error
%HTTP_HTTPS-E-DIAGNOSTICS: ERROR - in <RL_scalarGet> tag, can not get the MIB scalar: rlCopyMirrorEnable.
 - Report to : https://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
 M.
I don't have TAC or service contract and it wouldn't worth to make one for a homelab device.
So it is a brick, isn't it?
                  >...I don't have TAC or service contract and it wouldn't worth to make one for a homelab device.
Note that these devices , are intended for business use (market) ; companies will usually invest in support contracts if they value business (operations).  For home use , buy products accordingly
 M.
It was probably long time ago when you were at the beginning of your career and things worked differently that time. Nowadays companies expect you to know things that you don't use day by day or yet, so you have to practice a lot and the best way to practice buy real devices into your homelab and learn things at home. That's how I learnt how to interoperate different brand devices, setting up embedded service service engine and many other things. At the office I neither have time nor allowance to play with customer devices.
I work for a big multinational company and we provide support to our customers not Cisco as most of the companies use many different brand together in their network and we are cheaper than the separate supports from the manufacturers. So buying TAC is not as common as you expect it.
For my home network I bought a Cisco Refresh "new" wireless router which web gui obviously doesn't work properly. Cisco still seems having problems to manufacture a working web gui for its devices
As this SG200 doesn't have CLI I have to declare it being a nonworking brick.
RAM Memory Log TableShowing 1-39 of 3910203050per pageLog Index Log Time Severity Description
21474836092019-Apr-16 17:49:46Informational%AAA-I-CONNECT: New http connection for user cisco, source 192.168.1.253 destination 192.168.1.254 ACCEPTED
21474836102019-Apr-16 17:46:05Informational%INIT-I-Startup: Cold Startup
21474836112019-Apr-16 17:44:42Notice%SYSLOG-N-LOGGING: Logging started.
21474836122019-Apr-16 17:44:06Warning%STP-W-PORTSTATUS: gi1: STP status Forwarding
21474836132019-Apr-16 17:44:06Warning%STP-W-PORTSTATUS: gi25: STP status Forwarding
21474836142019-Apr-16 17:44:02Informational%LINK-I-Up:  Vlan 2024
21474836152019-Apr-16 17:44:02Informational%LINK-I-Up:  gi1
21474836162019-Apr-16 17:44:01Informational%LINK-I-Up:  gi25
21474836172019-Apr-16 17:43:59Informational%NSFP-I-SFPGibicDetected: gi26 SFP port is present, module type - 1000BASE-SX
21474836182019-Apr-16 17:43:59Informational%LINK-I-Up:  loopback1
21474836192019-Apr-16 17:43:59Warning%LINK-W-Down:  gi26
21474836202019-Apr-16 17:43:58Warning%LINK-W-Down:  gi25
21474836212019-Apr-16 17:43:58Warning%LINK-W-Down:  gi24
21474836222019-Apr-16 17:43:58Warning%LINK-W-Down:  gi23
21474836232019-Apr-16 17:43:58Warning%LINK-W-Down:  gi22
21474836242019-Apr-16 17:43:58Warning%LINK-W-Down:  gi21
21474836252019-Apr-16 17:43:58Warning%LINK-W-Down:  gi20
21474836262019-Apr-16 17:43:58Warning%LINK-W-Down:  gi19
21474836272019-Apr-16 17:43:58Warning%LINK-W-Down:  gi18
21474836282019-Apr-16 17:43:58Warning%LINK-W-Down:  gi17
21474836292019-Apr-16 17:43:58Warning%LINK-W-Down:  gi16
21474836302019-Apr-16 17:43:58Warning%LINK-W-Down:  gi15
21474836312019-Apr-16 17:43:58Warning%LINK-W-Down:  gi14
21474836322019-Apr-16 17:43:58Warning%LINK-W-Down:  gi13
21474836332019-Apr-16 17:43:58Warning%LINK-W-Down:  gi12
21474836342019-Apr-16 17:43:58Warning%LINK-W-Down:  gi11
21474836352019-Apr-16 17:43:58Warning%LINK-W-Down:  gi10
21474836362019-Apr-16 17:43:58Warning%LINK-W-Down:  gi9
21474836372019-Apr-16 17:43:58Warning%LINK-W-Down:  gi8
21474836382019-Apr-16 17:43:58Warning%LINK-W-Down:  gi7
21474836392019-Apr-16 17:43:58Warning%LINK-W-Down:  gi6
21474836402019-Apr-16 17:43:58Warning%LINK-W-Down:  gi5
21474836412019-Apr-16 17:43:58Warning%LINK-W-Down:  gi4
21474836422019-Apr-16 17:43:58Warning%LINK-W-Down:  gi3
21474836432019-Apr-16 17:43:58Warning%LINK-W-Down:  gi2
21474836442019-Apr-16 17:43:57Warning%LINK-W-Down:  gi1
21474836452019-Apr-16 18:43:54Informational%SNMP-I-CDBITEMSNUM: Number of startup configuration items loaded: 123
21474836462019-Apr-16 18:43:54Informational%SNMP-I-CDBITEMSNUM: Number of running configuration items loaded: 123
21474836472019-Apr-16 18:43:42Informational%INIT-I-InitCompleted: Initialization task is completed
