03-11-2015 08:54 AM
I have multiple SG200-50 switces which i have successfully upgraded the boot code and firmware without issues.
However one switch simply refuses to be upgraded via HTTP or TFTP, it is running FW 1.2.9.44 and Boot 1.1.0.6.
I have downloaded all FW versions from Cisco including earlier versions and no matter what version i use or method to load it onto the switch i keep getting an illegal software format message for FW and wrong boot file format when trying to load the boot code.
I have also done a full factory reset and tried all of the above again, but unfortunatly with the same issues.
Any help will be greatly appriciated.
03-11-2015 01:49 PM
Hello:
Below is the link to the SG200 firmware:
https://software.cisco.com/download/release.html?mdfid=283771818&flowid=24301&softwareid=282463182&release=1.0.0.19&rellifecycle
Please make Sure that you are using the SG200 FW and boot.
Also, you must step up the firmware:
1.3.0.6 --> 1.3.7.18 -> 1.4.0.88
--> Boot 1.3.5.06
Regards, Mike
03-12-2015 12:38 AM
Guys,
Thank you for your reply's but i dont think you have fully understood my current suituation.
I am fully aware of the intrim step-up and had to do it for all the other switches, this particular one however will not accepet any firmware regardless of its version, i have even tried to step it down one version with the same results. I have downloaded and tried every single version availabe from Cisco all without success.
03-12-2015 09:37 AM
If you are using the correct firmware and boot files for the SG200, then you may have a hardware issue.
Please give Cisco support a call at 866.606.1866.
03-12-2015 11:52 AM
Thank You Michael,
From that number i was able to get the UK number, i will contact them tomorrow when they open again.
03-11-2015 08:51 PM
HI,
Use the below Link:
https://supportforums.cisco.com/discussion/12286911/sg300-firmware-upgrade-copy-illegal-software-format
You need to do same for SG200 switch
02-10-2016 04:13 AM
For the sake of helping others, I want to share the solution with everyone:
1. Update boot code to version 1.3.5.06 (I did this part with a tftp server. Just point the webui to the ip address and filename of your tftp server).
2. Reboot
3. Update to firmware "sx200_fw_1.3.7.18.ros"
4. Reboot
5. Do a factory reset on router.
6. Proceed to updating to the latest Version.
7. Celebrate by having a desired beverage.
