SG200-50 PVID on trunk ports
dave23189
Hi all,
I have a couple of Cisco SG200-50's both of which have 2 trunk ports with various VLANs on them.
When i made them trunk ports it auto assigned them PVID 4095.
I am trying to change the PVID for these ports to 1 but the setting doesn't change!
I have many SG300's and have set this no problem.
Both SG200's are on firmware 1.3.0.59
the default VLAN ID is 1
Any ideas?
thanks in advance
Dave
dave23189
Noone?
I have notices that if i go into the Port VLAN Membership and click join VLAN VLAN 1 is forbiden, if i remove VLAN 1 and add it as Untagged the PVID box is ticked but when i click Apply i get this error:-
bxm_cur_node_null
Thanks in advance
Dave
Hi Travers, it sounds to me you should change your trunk to access mode to force the link to an untag member of one vlan. Then change the native vlan to any vlan you desire while still in access mode. Once done changing the vlan ID while the port is access mode, convert it back to trunk then configure the trunk as desired.
-Tom
Please mark answered for helpful posts
-Tom Please mark answered for helpful posts http://blogs.cisco.com/smallbusiness/
