SG200 Not working gige vision cameras
sungyeolyang
Hello.
I bought the SG200 switch and the Sg300-10 switch.
It supports POE.
Of course I have enabled jumbo frames in the port settings.(on the Web)
But my GiGe camera does not get good images.
It works very well when i replace it with a Netgear hub.
I am convinced that this is a configuration issue on the Cisco Hub.
I think we should set the MTU.
I was connected to the console
System MTU command does not work. It's a false command response.
For machine vision cameras, jumbo frames are very important and MTU settings are important.
Where should I set it
If you are setting up with the CLI, please log in with a friendly explanation from the next step
0 Replies 0
