12-03-2013 05:12 AM
I am using a SG200 to expand a small office area. It will run to computers and Cisco 7960 IP phones. I have attached a simple topology diagram for reference.
The 2960 port configuration is as follows:
interface GigabitEthernet1/0/14
description Squadroom LNHPDSW3 - Jack D04
switchport trunk native vlan 5
switchport trunk allowed vlan 1,5,10,50
switchport mode trunk
switchport voice vlan 50
priority-queue out
mls qos trust cos
spanning-tree portfast
On the SG200, the ports look like this:
PC work just fine and are on the correct VLAN. The IP PHONES will not switch to the voice vLAN, which is vLAN 50. The phones don't have any PC connected to them, if that would make a difference. Have I missed a configuration on the SG200 to all for the voice vlan to be assigned to the IP Phone connected to ports 1 and 2.
Also, if there are any other recommendations for this configuration, please do recommend.
Thanks in advance,
John
12-03-2013 05:47 AM
On Your 2960,config should be like this
priority-queue out
mls qos trust cos
On Cisco sg-200,login through GUI,enable telnet service and access through cli and type this command
inter gi 14
swithport trunk native vlan 5
switchport trunk allowed vlan add 1,10,50
no lldp transmit
exit
also in global config mode type
(config)#voice vlan id 50
** this will create vlan 50
(config)#voice vlan state auto-enabled
now both ip phone and pc will work on same port.
Guru
12-03-2013 07:24 AM
Guru,
The SG200 doesn't have CLI access; unless I am missing something. So how do you do this via the GUI?
John
