SG250-08HP - the led flashes
I have a problem with the Cisco SG250-08HP switch, after connecting it to the power supply, the System LED flashes green, after a few moments all LEDs in the lan ports light up and the procedure repeats over and over again.
What is wrong ??
marce1000
 - The device may be looking for a DHCP server to get an address , you may provision it's mac address in your DHCP service/server (e.g.)
 M.
balaji.bandi
Is this new switch ? Try reset to Factory Default and use Quick Start guide :
https://www.cisco.com/c/dam/en/us/td/docs/switches/lan/csbss/sf_sg250/quick_start/guide/en_US/78-100762-01A0.pdf
use console cable and check on the console and capture all the boot log and post here :
https://www.cisco.com/c/en/us/td/docs/switches/lan/csbms/250_/2_5_7/Admin_guide/tesla-250-ag/get-to-know-your-switch.html
BB
Thanks for the hints, but now none of the ports on the switch are working.
Unfortunately, this switch does not have a console input.
Holding the reset button for more than 10 seconds does not help.
