SG250 "H" models PoE specs
tato386
Level 6
Level 6
Does anybody know what the "H" stands for in models like SG250-26HP and SG250-50HP?  I thought it stood for "high" power because the "HP" models tend to be more expensive that the plain "P" models.  However, the Cisco data sheets have the "H" models with -less- power than then non-H??
SG250-26HP 100W 24
SG250-26P  195W 24
SG250-50HP 192W 48
SG250-50P  375W 48
luis_cordova
Hi @tato386 ,
As far as I remember:
HP: Half PoE
P: PoE
FP: Full PoE
luis_cordova
Hi @tato386 ,
HP: Half PoE
P: PoE
FP: Full PoE
Yeah, I think you are right. I was confused because Amazon pricing showed the P model cheaper than HP but when I checked a couple other sites the P model was always more expensive which makes sense. Thank you!
