10-10-2022 04:59 AM
Dear Sir/Madam
I have a strange issue with the vlan on SG250.
I have a proper vlan configuration, and disable gvrp.
but my vlan config will auto change after reboot.
for what I find now, it success to load the vlan config during startup.
but when it detect the upper level switch, the vlan will auto jump to other setting.
I have no idea why and would like to see if someone can provide some idea to me.
Thank you
Vanness
10-10-2022 05:53 AM
check any smartport option enabled ?
10-10-2022 05:58 AM
I have disable the smartport already.
I also try to disconnect all the other network port and reboot it, and still remain the same
10-11-2022 02:17 AM
I have solve the issue, the Administrative auto smartport disable is not means the smartport disable
when I disable the smartport one by one, the issue was solved.
10-11-2022 04:10 AM
yes when you disable globally the config should effect all port, but some time config already available in port may be that is the issue i guess. glad you able to resolve the issue with the suggestion. we mark as resolved now.
