SG250X-24P Support
fjcharton
I am having issues with two separate SG250X-24P units. Last week they suddenly stopped working and supporting the network. The main wifi router works fine and can be used with WiFi and Ethernet directly. The port used to support our WiFi repeaters (Gigamedia) but has stopped working. The line has been checked by technicians and seems to be fine. Any idea if there needs to be something done with the units or is the issue elsewhere?
Many thanks
7 Replies 7
balaji.bandi
how does the port config looking like
can you post show run (provide what port connected) ?
BB
Hi Balaji,
I’m not too technically gifted so here are images of the set up.
Hope that helps?
images dont help.
BB
What would that involve? How do I show run?
Login to switch using SSH connection,
once you see # (prompt) - issue command show run
BB
How do you do this on a Mac. And how do you connect to the switch? Ethernet into which port?
This easy tutorial will show you how to connect the cisco switch via SSH client.
