SG300-10 - can't upgrade?
cscosw
yesterday I bought used Cisco SG300-10 for home using.
I found some problems.
1. console cable doesn't work, don't understand why so I enabled SSH via webui, connecting to ssh now
2. I can't upgrade firmware.
The very first of all I downloaded
https://software.cisco.com/download/home/283019615/type/282463181/release/1.4.1.03
Used copy tftp://10.31.0.12/sx300_boot-13506.rfb
rebooted switch
But if I want to upgrade ros, tfp can't download it. Tried 2 versions - 1.4.1.03 and 1.4.11.04.
Any help please?
Thank you
cisco-sw1#copy tftp://10.31.0.12/sx300_fw-14114.ros image
12-Nov-2011 23:36:37 %COPY-I-FILECPY: Files Copy - source URL tftp://10.31.0.12/sx300_fw-14114.ros destination URL flash://image
12-Nov-2011 23:36:37 %TFTP-A-TftpTxERROR: An error message was sent: 0 <Closed by application>
12-Nov-2011 23:36:37 %COPY-W-TRAP: The copy operation has failed
Copy: Illegal software format
cisco-sw1#copy tftp://10.31.0.12/sx300_fw-1424.ros image
12-Nov-2011 23:46:48 %COPY-I-FILECPY: Files Copy - source URL tftp://10.31.0.12/sx300_fw-1424.ros destination URL flash://image
12-Nov-2011 23:46:49 %TFTP-A-TftpTxERROR: An error message was sent: 0 <Closed by application>
12-Nov-2011 23:46:49 %COPY-W-TRAP: The copy operation has failed
cisco-sw1#sh ver
SW version    1.1.2.0 ( date  12-Nov-2011 time  23:34:26 )
Boot version    1.3.5.06 ( date  21-Jul-2013 time  15:12:10 )
HW version    V02
cisco-sw1#sh bootvar
Image  Filename   Version     Date                    Status
1      image-1    1.1.2.0     12-Nov-2011  23:34:26   Not active
2      image-2    1.1.2.0     12-Nov-2011  23:34:26   Active*
"*" designates that the image was selected for the next boot
marce1000
 1) Check the logs of your tftp server, watch for errors - if any. 2) What kind of tftp server/platform are you using ?
 M,
1. why do I need to check tftp server logs? It's serial cable which doesn't work. I connect cable, but still see switch "down"
Upgrade already fixed. I musted to upgrade older firmwares before newest.
cisco-sw1#sh version
SW version    1.4.11.4 ( date  02-Dec-2019 time  00:24:26 )
HW version    V02
1      image-1    1.4.0.88    06-Aug-2014  16:55:55   Not active
2      image-2    1.4.11.4    02-Dec-2019  00:24:43   Active*
cisco-sw1#
Just can't find newer bootloader. Don't know if there is some newer version.
and in cisco website I see *.ros 1.4.11.4 which was released on 29th Jan 2020 but in ssh I see 1.4.11.4 02-Dec-2019. Don't know if it's ok :)
ajpareek
Please go through the below URL to upgrade the firmware via tftp :
https://www.cisco.com/c/en/us/support/docs/smb/switches/cisco-small-business-200-series-smart-switches/smb950-firmware-upgrade-via-tftp-on-200-300-series-managed-switches.html
Please ensure that the device is connected properly and you are using the latest version of tftp application.
Ajay Pareek
