02-24-2015 12:19 PM
S14-DPAS-SW10#show logging file Logging is enabled. Origin id: disabled Console Logging: Level info. Console Messages: 0 Dropped. Buffer Logging: Level info. Buffer Messages: 68 Logged, 68 Displayed, 1000 Max. File Logging: Level error. File Messages: 55 Logged, 70 Dropped. 3 messages were not logged Application filtering control Application Event Status -------------------- -------------------- --------- AAA Login Enabled File system Copy Enabled File system Delete-Rename Enabled Management ACL Deny Enabled Aggregation: Enabled Aggregation aging time: 300 Sec 24-Feb-2015 15:12:43 :%2SWVLAN-F-VLNDELPORT: vlan_port_del: Error code Operation failed when deleting ifIndex 54 from vlan 200 ***** FATAL ERROR ***** Reporting Task: BRMN. Software Version: 1.4.0.88 (date 06-Aug-2014 time 16:55:55) 0x16aee8 0x16b44c 0x16700c 0x74a724 0x4ca294 0x4cab8c 0x4cada8 0x9bf7dc 0x80536c 0x809770 0x8134e8 0x81f69c 0x87d5cc 0x884dac 0x88acd8 0x87c85c 0x772790 0x84a5a0 0x84dd84 0x7bc8c4 0x7c66e4 0x7cc1f0 0x674edc 0x1223f0 ***** END OF FATAL ERROR ***** 24-Feb-2015 15:03:33 :%2SWVLAN-F-VLNDELPORT: vlan_port_del: Error code Operation failed when deleting ifIndex 54 from vlan 200 ***** FATAL ERROR ***** Reporting Task: BRMN. Software Version: 1.4.0.88 (date 06-Aug-2014 time 16:55:55) 0x16aee8 0x16b44c 0x16700c 0x74a724 0x4ca294 0x4cab8c 0x4cada8 0x9bf7dc 0x80536c 0x809770 0x8134e8 0x81f69c 0x87d5cc 0x884dac 0x88acd8 0x87c85c 0x772790 0x84a5a0 0x84dd84 0x7bc8c4 0x7c66e4 0x7cc1f0 0x674edc 0x1223f0 ***** END OF FATAL ERROR ***** S14-DPAS-SW10#
I had two of these in a row now. It happened when I unplugged a device from the switch. I am not sure if there is some sort of known issue with this switch or am I seeing a hardware failure.
S14-DPAS-SW10#show version SW version 1.4.0.88 ( date 06-Aug-2014 time 16:55:55 ) Boot version 1.3.5.06 ( date 21-Jul-2013 time 15:12:10 ) HW version V02 S14-DPAS-SW10#
Any advice? Any more info needed?
Solved! Go to Solution.
02-24-2015 05:06 PM
Looks like hardware failure.
Kindly raise the service request with TAC team.
TAC contact details as below:(use below link)
http://www.cisco.com/c/en/us/support/web/tsd-cisco-small-business-support-center-contacts.html
regards
Moorthy
02-24-2015 05:06 PM
regards
Moorthy
02-25-2015 07:11 AM
I've submitted a case and information to support.
Thanks for the advice.
